Nylander88 Posted June 3, 2020 Share Posted June 3, 2020 I found these sweet looking midi controllesr, would these work with the midi functionality on an Hx Stomp? https://www.long-mcquade.com/6363/Guitars/Guitar_Effects/Behringer/MIDI_Foot_Controller.htm https://www.long-mcquade.com/160220/Guitars/Guitar-Effects/Singular-Sound/MIDI-Maestro-Control-Pedal.htm Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 3, 2020 Share Posted June 3, 2020 Yes, but keep in mind that it is a VERY big unit. That said, If you decide to get one (they're usually available used for <>$100US), I can send you a configuration file for using it with the Stomp. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 3, 2020 Share Posted June 3, 2020 I don't know the other one, but I couldn't find a proper configuration manual for it, which is not a good sign with a MIDI device..... 1 Quote Link to comment Share on other sites More sharing options...
Nylander88 Posted June 3, 2020 Author Share Posted June 3, 2020 7 minutes ago, rd2rk said: Yes, but keep in mind that it is a VERY big unit. That said, If you decide to get one (they're usually available used for <>$100US), I can send you a configuration file for using it with the Stomp. Cool thanks! 3 minutes ago, rd2rk said: I don't know the other one, but I couldn't find a proper configuration manual for it, which is not a good sign with a MIDI device..... Weird Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 3, 2020 Share Posted June 3, 2020 Also, consider that the FCB1010 can only address 100 of the 128 presets available on your Stomp. By the time you get the Sanpshots and 5 buttons programmed, you're down to 90. And, while it does have two expression pedals, they are not well known for accuracy, and there's no toe switches. The FCB1010 is, however, nigh on indestructible..... Quote Link to comment Share on other sites More sharing options...
Nylander88 Posted June 3, 2020 Author Share Posted June 3, 2020 6 minutes ago, rd2rk said: Also, consider that the FCB1010 can only address 100 of the 128 presets available on your Stomp. By the time you get the Sanpshots and 5 buttons programmed, you're down to 90. And, while it does have two expression pedals, they are not well known for accuracy, and there's no toe switches. The FCB1010 is, however, nigh on indestructible..... Thanks for answering my posts I think this may be better though the beringer board looks awesome https://www.long-mcquade.com/67933/Guitars/Guitar-Effects/Roland/ES-5-Boss-Effects-Switching-System.htm ( Ithink this would work with the stomp) Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 3, 2020 Share Posted June 3, 2020 If you have other external stompboxes that you want to integrate with your Stomp, it's a popular choice. As a pure MIDI controller it's a costly solution, and not all that much more powerful than other, smaller choices, such as: https://www.morningstarfx.com/ 1 Quote Link to comment Share on other sites More sharing options...
Nylander88 Posted June 3, 2020 Author Share Posted June 3, 2020 3 minutes ago, rd2rk said: As a pure MIDI controller it's a costly solution, and not all that much more powerful than other, smaller choices, such as: Those are cool controllers, I'll have to keep those in mind. Quote Link to comment Share on other sites More sharing options...
