Sign in to follow this
kevinrojo
FBV VOLUMEN CONTROL
hi I have a line 6 spider IV + FBV Pedal.The pedal doesn't work when I want to turn the volume up or down.
How can I configure that option?
Which FBV pedal?  Is it currently in Wah mode?  If so, you need to step (hard) on the toe of the pedal to switch to Volume mode.
is an FBV EXPRESS MKll,
when i connect it to my line 6 spider IV, the pedal doesn't control the volume, and the "wah" mode doesn't work either.
Is it possible the Cat 5 cable or the connectors on it have been bent or damaged?  The first thing I would do is check with another CAT5 cable.  Assume you have had this for a while or bought it used, the cables are unfortunately very fragile.
