Lone_Poor_Boy Posted June 21, 2020 Share Posted June 21, 2020 EDIT: this would only be used for goofing around with a bass player to try different FX. I plan to build my own but always like to see someone's framework first. I plan to setup for two people playing at the same time, totally separated, one electric guitar, one electric bass, both coming in 1/4" inputs. I'll likely be using both 1/4" and XLR outs for both instruments to feed amps (1/4") and PA (XLR). Related question: I planned to mainly power the bass by running Helix into a basic bass amp. Ampeg Rocket Bass B-100R, into the 1/4"; 0db or -15db. I was also going to split into the Fishman SA-330x PA w/sub. Would a bass sound ok through this PA, post Helix, since it has the sub? Would bass 'overwhelm' a PA of that type? Guitar will be split as I normally do: 60% Powercab 112+; 40% Fishman PA. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 21, 2020 Share Posted June 21, 2020 Here's what the mfr says about their own product: The SA330x is the go-to portable PA/amplifier for voice, playback and amplified acoustic instruments. Unlike many other similar-looking systems, the SA330x is built around a uniquely configured 2-way speaker system that delivers all the sweetness and definition of a great studio monitor. Ruggedly built and with plenty of power, the SA330x is the perfect solution for amazing sound in small and medium-sized venues. Tuned beautifully for voice and acoustic instruments, the new SA330x, alone or as part of an expanded system, allows anyone looking to fill a small to medium sized room, corporate display, club or similar sized venue with great, Fishman-quality sound. --------------------------------------------------------------------------------------------------------------------------------------------------------------------------- If I was looking for a PA to do what you're planning, I wouldn't get this one. BUT - if you're planning on using it for lite rock/blues, jazz or folk, at dinner club volumes, it might be just fine. Attached is a sample preset. It's essentially a 'template" for all my dual instrument presets, I just swap out effects as needed. On Path A I'm sending the guitar left to my PC112+, and right out the XLR to a HR FRFR112. Path B is bass out the XLR to the other FRFR112 input. LPB.hlx Quote Link to comment Share on other sites More sharing options...
Lone_Poor_Boy Posted June 21, 2020 Author Share Posted June 21, 2020 RD2RK, Thank you very much for the preset! I should have noted this would only be used to goof around with a bass player friend to try Helix FX. I got some ideas from a John Entwhistle video the other day. As you implied, I would not want to run a bass through this Fishman. Quote Link to comment Share on other sites More sharing options...
