JAROPDA Posted June 23, 2020 Share Posted June 23, 2020 Since I had time and had never opened it ... Well, I was encouraged. At least in the variax 600 model the pots are mounted on the pickguard, I observed that right next to the guitar model selector it had a metal point so you know what model you are, coinciding with the point on the model name, Well, it occurred to me to place a red led in that hole already made to do the same function and to see the Bank where you are playing even in the dark illuminated and this is how it turned out, I really liked the result, it gives you a more sophisticated appearance. Well nothing so far my entertainment today and my new mod variax 600. The led works both with batteries and with the cable. Quote Link to comment Share on other sites More sharing options...
moonsai98 Posted January 1, 2021 Share Posted January 1, 2021 Fantastic! How you connect the led to the main board or the power supply ? Quote Link to comment Share on other sites More sharing options...
JAROPDA Posted January 1, 2021 Author Share Posted January 1, 2021 The installation is very simple, you have to follow the battery power cable to the printed circuit, there you solder the + and - cables that you will solder to a led.In the long side of the led, insert a resistance of value x 470 ohm in my case and you the one that you see suitable for your brightness, and you place it in the already made hole, I only enlarged it a little more ... make sure to isolate each leg of the led well with heat shrink. bank are you .... Quote Link to comment Share on other sites More sharing options...
moonsai98 Posted January 2, 2021 Share Posted January 2, 2021 Many thanks and I will try this in the coming weeks (as I need to find the resistor). Quote Link to comment Share on other sites More sharing options...
moonsai98 Posted January 2, 2021 Share Posted January 2, 2021 One more question is if I follow the battery cable’s + and - and solder the led with a resistor, will it light permanently as I always connect the battery pack. Should I solder the + somewhere that the power will only provided after inserted the guitar cable. Thank you. Quote Link to comment Share on other sites More sharing options...
