Using 2 PowerCab 112+ with Helix and/or Variax
Hi, All...
I am running Helix Rack with Controller and 3 expression pedals....
I also have 2 PowerCab 112+, with the first connected to Helix Vix 6 Link, and the second PowerCab 112+ connected to the first with 6Link as well.
I am running 2 separate paths in Helix.   Input for Path 1 is Variax (VDI) and Input for Path 2 is Guitar (for my daughter's Ovation)
I am trying to have each path output directed to separate PC+.  The problem is, when I select PC+ (#1) in output block of Path 1 it changes the Output Path 2 to the same PC+.
Am I missing something? Only using MONO effects between Input and Output...
V-ax Acou 2Gtr.hlx
  • 2 months later...
Hello Tim...
Unfortunately, I think you have to downgrade to the Pod HD500 series. I want to do something similar whereby I split my Variax mags to output to a DT50 and the Variax modelling to a PC+. The answer I got in another post was that it wasn't possible with the Helix because of a different routing architecture. However, it looks like it's possible using a Pod HD500 as demonstrated in this video:
