anthdidj Posted June 30, 2020 Share Posted June 30, 2020 For some reason when I put a fuzz block in the signal chain and turn it off, it sounds like a blanket is thrown over the amp. I have to reset the patch to get the sound of the amp to be normal again. If I save the amp with a fuzz in the signal path in bypass the patch is ruined i.e. it permanently sounds like the blanket is on and I have to rebuild the patch. Any ideas? Quote Link to comment Share on other sites More sharing options...
Lone_Poor_Boy Posted June 30, 2020 Share Posted June 30, 2020 If you search 'fuzz' I think you'd find a lot of good discussions covering this inside the posts, like this one; 1 Quote Link to comment Share on other sites More sharing options...
anthdidj Posted June 30, 2020 Author Share Posted June 30, 2020 awesome thank you for that Quote Link to comment Share on other sites More sharing options...
Lone_Poor_Boy Posted June 30, 2020 Share Posted June 30, 2020 You're welcome. I'm still learning (and always will be) so I read a lot on here and there was a lot of good recent discussion around fuzz, instruments, pedals, bypass and true bypass, and input impedance and how some things work one way, but some thinks act differently. More than one discussion. I'm still taking it in or I'd speak to it in response. Quote Link to comment Share on other sites More sharing options...
emagli Posted July 2, 2020 Share Posted July 2, 2020 If the fuzz is the first pedal in the chain (like it usually is), it may set the input impedance to a low value. When on "auto", the input impedance is set by the first block in the chain, whether it is active or bypassed. The vast majority of blocks sets the impedance to 1 MOhm, but a few blocks (and notably a few fuzz blocks) set it to a lower value. This will indeed make your tone darker if the fuzz is off. You can verify whether this is the problem by putting another (bypassed) block before the fuzz and see if the tone changes. Quote Link to comment Share on other sites More sharing options...
