Spider V Remote 2.00 and Windows 10
jocko3147
Why am I having this problem?
It seems to happen when I try and switch from Full range to classic.
The program Spider V Remote.exe version 2.0.0.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
 Process ID: 35b0
 Start Time: 01d656e4f33d8780
 Termination Time: 5
 Application Path: C:\Program Files (x86)\Line6\Spider V Remote\Spider V Remote.exe
 Report Id: 44547161-8749-4310-9346-98d8fbc84395
 Faulting package full name:
 Faulting package-relative application ID:
 Hang type: Unknown
I have same problem... crashes when switching from full range to classic every time.
It is obviously a bug in the Spider program causing crash.
I am running Windows 10 2004
Have not tried on my MacBook though yet.
  • 2 weeks later...
I opened up a ticket with Line 6. tried what the said to do with no luck.
Thanks for providing that info. I just tried what you said here, and I'm not getting any hanging with Windows 10 that you're describing. So it seems it could be a system issue.
The best thing I would recommend is trying out different USB ports or cables when you're connecting to the amp. Make sure your Window 10 system is completely updated.
If those suggestions don't help, then you may want to try out another computer.
Thanks,
Pete
Line 6 Support
  • 1 month later...
me to doesn't work on win 10 works great on my ipad. it shows up as a sound option though its just remote crashes. I can record from it and send sound to it.
Application: Spider V Remote.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
   at WindowsCommon.EngineInterface.ParamValueServer.createEngine()
   at WindowsCommon.EngineInterface.ParamValueServer..ctor()
   at WindowsCommon.EngineInterface.ParamValueServer..cctor()
Exception Info: System.TypeInitializationException
   at WindowsCommon.EngineInterface.ParamValueServer.get_Instance()
   at MainApplication.MainWindow.<.ctor>b__10_0()
   at System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
   at System.Threading.ThreadHelper.ThreadStart()
Faulting application name: Spider V Remote.exe, version: 2.0.0.0, time stamp: 0x5d3085bd
Faulting module name: KERNELBASE.dll, version: 10.0.18362.1049, time stamp: 0xc4675baa
Exception code: 0xe0434352
Fault offset: 0x001144c2
Faulting process id: 0x2390
Faulting application start time: 0x01d68bcc30bb18fb
Faulting application path: C:\Program Files (x86)\Line6\Spider V Remote\Spider V Remote.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: 06af4164-9514-4123-a740-3ef44e4002c8
  • 4 weeks later...
 I have the same exact error on a freshly installed Windows 10 Pro 2004. Digital Audio (recording and playback) is working fine, Spider V Remote software can not be opened.
EDIT: It worked after installing Visual C++ 2013 x86 redistributable. Don't know why the setup ships with the 2017 version. Unfortunately, Line6 first level support was of no help. This error was first reported one year ago, I don't know why they don't engage more in their own forum.
  • 1 year later...
