HX Stomp with fender spring reverb unit
Samdbl
Thinking of going direct with the hx stomp for a solo surf gig i have coming up. However, I can't get a good fender 'drip' tone from the reverb in the stomp (yes I've tried the tutorial that's on youtube). So, if I were to use my actual fender spring reverb unit, what would be the best way when going direct with the stomp? Like the reverb at the end of the chain. Yet, I want to keep the delays on the stomp in stereo. So I think I should put the tank in the loop, and then put the loop at the end of the chain in my signal flow internally. Would that be correct?
If you want it to sound like it does in the amp, I would have a separate amp and speaker cab and put it in between those two blocks using the FX loop but that would make it mono. For stereo you will have to use two of the effects RETURN's with two of the same cab on parallel paths after being split from the amp. Have a SEND after the amp, going out to the reverb unit's input BUT the stereo outputs of the reverb need to go into two separate effects RETURN's each RETURN block positioned before one of the two parallel cabs respectively. Does this make sense?
The tutorial that I think you're referring to got about as close as you're going to get with the Helix. Is this the video you are referring to?
