erikfabler Posted August 13, 2020 Share Posted August 13, 2020 Hi, Is it possible to assign multiple funtions for the expression pedal? Eg. basic setup for the expression pedal is volume, and wah-wah when activated. And, when you activate a specific stomp box or snapshot, you can then adjust a specific parameter of an effect instead with the expression pedal - bypassingn the volume function? thx for any help or suggestions (share presets) Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 13, 2020 Share Posted August 13, 2020 1 hour ago, erikfabler said: Hi, Is it possible to assign multiple funtions for the expression pedal? Eg. basic setup for the expression pedal is volume, and wah-wah when activated. And, when you activate a specific stomp box or snapshot, you can then adjust a specific parameter of an effect instead with the expression pedal - bypassingn the volume function? thx for any help or suggestions (share presets) Hi, There are many things that you can activate or modify with the expression pedal. Changing the feedback amount and delay times within a delay block is a typical example. You can assign your pedal to change whatever you like, it 's just a matter of "telling" the pedal what to control and when. He is a video of a guy doing a simple little thing with a whammy effect. For an in depth look at what you can do with the expression pedal by assigning to to various functions you should take some time and watch this. Hope this helps/makes sense Quote Link to comment Share on other sites More sharing options...
erikfabler Posted August 13, 2020 Author Share Posted August 13, 2020 Awesome! Thank you! I will look into this. 1 Quote Link to comment Share on other sites More sharing options...
