Run External Stereo Delay Pedal In Helix
ACinemaStare
I'm trying to run my Boss DD-200 through the FX Loop in stereo through my Helix Floor. I am only hearing sound out of one monitor so I wanted to see if I have this correct.
Send 1 in FX loop 1 to send 1 on pedal
Return 1 in FX loop 1 to return 1 on pedal
Send 2 in FX loop 2 to send 2 on pedal
Return 2 in FX loop 2 to return 2 on pedal
Created a stereo send block with send 1/2 and a stereo return block with fx loop 1/2. Should I do a split there with the return block on a different parameter and use a a/b split?
I haven't run a pedal in stereo before so I don't even know if I have this right or not. I know how to set up a guitar pedal in mono. Just looking for some help to how to correctly set that up in stereo. Thanks.
You only need to use the single stereo FX Loop 1/2 block in your preset. You don’t need a separate Send block. As far as connections it would be:
Helix Send 1 —> DD-200 Left In
Helix Send 2 —> DD-200 Right In
DD-200 Out Left —> Helix Return 1
DD-200 Out Right —> Helix Return 2
All the paths in the Helix are stereo, but in order for stereo separation to be maintained, any blocks, if any, you use after the FX Loop block would need to be stereo. You
