voxman55 Posted August 30, 2020 Share Posted August 30, 2020 In preset foot-switch mode when you press bank up/down the presets 'flash' on/off to indicate these are queued ready for loading. But I find the flashing distracting and makes it harder to see the queued presets. Does anyone else find this, and is there anyway to turn this flashing off? Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 30, 2020 Share Posted August 30, 2020 It can't be turned off. It's the same way with all Helix products, and I believe before that as well. As I'm sure you know it's there as a visual indicator that you are in the process of selecting a new preset, and you must either Cancel out of the process or select a preset. It's useful to alert you if you mistakenly hit the Up or Down switch. If you've organized you preset order in advance for a gig, as most do, and hit the wrong switch while 'live' you could get quite confused and it could affect your performance. Personally I find it more useful than annoying but I can see your point. Might be worth an Ideascale item as a global setting. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted August 30, 2020 Author Share Posted August 30, 2020 Thanks @silverhead I suspected that was the case but just thought I'd ask. Not bothered enough to put on ideascale as there are more important things Line 6 need to do. Quote Link to comment Share on other sites More sharing options...
