Spider IV 15W Amp Jack Trouble
NateCarnie
I recently just got into guitar and bought the Spider IV 15W amp. I tried to plug in my cord and no sound was coming out. I then noticed the only way the amp would work is if I put pressure on the cord into the jack. However once I let go it goes back to not working. Is there anyway I can fix this or should I look to return it?
First, try a different cord. Perhaps the one you’re using has a bit of a small plug.
Otherwise the internal jack connection is loose. If you’re comfortable fixing or replacing it yourself you can probably do so. If it’s brand new or under warranty I would return it or get it repaired by the dealer.
