Stigweard1985 Posted October 12, 2020 Share Posted October 12, 2020 Hi Line 6 Users, I have the POD GO and I am slowly learning how to use it... I am using an expression pedal with it so I can use both the Wah and Volume feature... does anyone know if there is a way to have the EXP LED turn on and off depending on whether you have the effect on or off? For example, when using the WAH, the LED is on when activated but off when deactivated? This happens automatically on my Spider IV when using the FVB Shortboard MKII but I can't work it out for the POD GO Many thanks Quote Link to comment Share on other sites More sharing options...
cristt Posted October 13, 2020 Share Posted October 13, 2020 well the leds are two, for exp1 and exp2 so they lit up when are engaged respectively, and that will be the case because you are using both volume and wah. I think the only way to have only the wah light lit up when it's on is to disable the vol for exp2. if I understood your question. Quote Link to comment Share on other sites More sharing options...
