Nylander88 Posted October 26, 2020 Share Posted October 26, 2020 Which ones work well with the hx stomp? would this work? https://www.long-mcquade.com/15780/Guitars/Cables_Power_Supplies/Voodoo_Lab/Voltage_Doubler_Adapter_-_18V_or_24V.htm and would this work with it? https://www.long-mcquade.com/70405/Guitars/Cables_Power_Supplies/Voodoo_Lab/2_1mm_Right_Angle_Barrel_Cable_-_24.htm Quote Link to comment Share on other sites More sharing options...
Schmalle Posted October 27, 2020 Share Posted October 27, 2020 The adapter you suggested doubles the voltage (by connecting two voltage source in series). Don't use that. You need 9V for the HX Stomp not 18V or 24 V. Some 9V pedal power supplies offer multiple isolated outs with 500mA max each. For those iit is possible to connect them in parallel to sum the available current (i.e. 500mA + 500mA =1000mA = 1A). 1 Quote Link to comment Share on other sites More sharing options...
Nylander88 Posted October 27, 2020 Author Share Posted October 27, 2020 8 hours ago, Schmalle said: The adapter you suggested doubles the voltage (by connecting two voltage source in series). Don't use that. You need 9V for the HX Stomp not 18V or 24 V. Some 9V pedal power supplies offer multiple isolated outs with 500mA max each. For those iit is possible to connect them in parallel to sum the available current (i.e. 500mA + 500mA =1000mA = 1A). Awesome, I think it's time for your "Iknowathingortwo" badge needs to be upgraded. Can't have a smarter person with the same Badge as me lol 1 Quote Link to comment Share on other sites More sharing options...
Nylander88 Posted October 30, 2020 Author Share Posted October 30, 2020 On 10/27/2020 at 1:56 AM, Schmalle said: The adapter you suggested doubles the voltage (by connecting two voltage source in series). Don't use that. You need 9V for the HX Stomp not 18V or 24 V. Some 9V pedal power supplies offer multiple isolated outs with 500mA max each. For those iit is possible to connect them in parallel to sum the available current (i.e. 500mA + 500mA =1000mA = 1A). https://www.long-mcquade.com/15778/Guitars/Cables_Power_Supplies/Voodoo_Lab/Current_Doubler_Adapter.htm Hey would this work? It's a current doubler (I would assume amps?) The other one was a voltage doubler Quote Link to comment Share on other sites More sharing options...
Schmalle Posted October 30, 2020 Share Posted October 30, 2020 41 minutes ago, Nylander88 said: https://www.long-mcquade.com/15778/Guitars/Cables_Power_Supplies/Voodoo_Lab/Current_Doubler_Adapter.htm Hey would this work? It's a current doubler (I would assume amps?) The other one was a voltage doubler Current is measured in ampere, right. That adapter has a jack. You would need a plug: https://www.logsdonaudio.com/cables/strymon-power-supply-and-line-6-pedal-current-doubler-cable Only use with a 9V power supply! 1 Quote Link to comment Share on other sites More sharing options...
Nylander88 Posted November 1, 2020 Author Share Posted November 1, 2020 On 10/30/2020 at 3:36 PM, Schmalle said: Current is measured in ampere, right. That adapter has a jack. You would need a plug: https://www.logsdonaudio.com/cables/strymon-power-supply-and-line-6-pedal-current-doubler-cable Only use with a 9V power supply! Thanks! Quote Link to comment Share on other sites More sharing options...
