Unable to Add IRs to HX Edit
carlsbro27
Hi,  I'm just getting started with Helix, I have upgraded ithe Helix to  V2.92  & HX Edit is V2.82, Iam trying to import IRs into the HX Edit software, for some reason the library will only allow me to add one IR, if I try to add another it looks like it imports but nothing appears in the list.  If I delete the IR I can add a different one in but only one.  Has anyone else experienced this?
Running this on Windows 10
Make sure you read the release notes carefully when you do an upgrade.  As noted in the release notes for 2.92, when you do an upgrade the normal process is to download the HX Edit install program and run it.  That will install HX Edit, all the appropriate device drivers, as well as upgrade the firmware on your Helix...all in one process.  That will ensure your HX Edit and Helix firmware versions are correct.
