ReeV0 Posted November 5, 2020 Share Posted November 5, 2020 Hi all, What isolated power supplies are you using for your pedalboards with a Stomp on it? That alone draws 1A, but most PSU's I've found only have a max of 500mah per outlet... This is my setup, currently running a Diago 3A daisy-chain but it's started to generate some noise :/ Quote Link to comment Share on other sites More sharing options...
ukphonebook Posted November 11, 2020 Share Posted November 11, 2020 Cioks is a good solution but you'll need a couple of adapter cables that allows you to link two of the 9v outs in parallel. You'll need a Cioks 3050 Flex Type 3... https://www.thomann.de/gb/cioks_3050_flex_typ_3.htm ...and a Cioks 8800 Parallel Adapter Flex... https://www.thomann.de/gb/cioks_8800_parallel_adapter_flex.htm My effects board is relatively small so I use a Cioks DC7 Quote Link to comment Share on other sites More sharing options...
ReeV0 Posted November 11, 2020 Author Share Posted November 11, 2020 I bought this instead, much cheaper than the Cioks https://www.ebay.co.uk/itm/Mosky-10-Outputs-Guitar-Effect-Pedal-Board-Power-Supply-9V-12V-18V-Cables/164363752513?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D225114%26meid%3D5d1edf4f67044dcd9181aa6e04a2b9e7%26pid%3D100675%26rk%3D2%26rkt%3D15%26mehot%3Dnone%26sd%3D154188929618%26itm%3D164363752513%26pmt%3D1%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3Af654a04e-2465-11eb-ae81-0672cec4ba3f|parentrq%3Ab93d1a041750a9cd66a882f6ffe0ff60|iid%3A1 Quote Link to comment Share on other sites More sharing options...
ukphonebook Posted November 11, 2020 Share Posted November 11, 2020 Hope you have better luck with it than I did. Lasted a couple of months and the seller wouldn't respond to emails etc. I suppose you get what you pay for. Quote Link to comment Share on other sites More sharing options...
DBCrocky Posted November 11, 2020 Share Posted November 11, 2020 I will second the recommendation of the Cioks DC7 with the correct adapter to run the HX Stomp. It's a solid power platform, doesn't weigh a ton, and fits nicely underneath a Pedal Train board. I don't recommend cheaping out on pedal power, you'll regret it for sure. Quote Link to comment Share on other sites More sharing options...
