panita Posted December 2, 2020 Share Posted December 2, 2020 Hello, well everything was working fine on my pod xt live, until one day I need to tune my guitars.... I press the tuner button for more than 2 secs and nothing happened, so I starting to deal with the problem and discover that pushing "OUTPUT MODE" and then turn clock wise the select button, the tuner appears. Can somebody tell me how can i put back the tuner to the pedal again? Thanks beforehand Quote Link to comment Share on other sites More sharing options...
daveny5 Posted December 2, 2020 Share Posted December 2, 2020 Sounds to me like your TAP button may be worn out. Does it feel like all the other buttons when you press it with your fingers? If you use it to tap a Delay effect, does it work? Quote Link to comment Share on other sites More sharing options...
unna Posted December 3, 2020 Share Posted December 3, 2020 Would you dare to press that button a bit harder? When I got my POD XT Live I thought the pedal was not working properly because I couldn't activate the _Wah_ function by pressing it. When I dared to push it much harder, it started working. Now I know that activating that function requires a much bigger pressure. That being said, I understand that a pedal and a button are not the same, and I wouldn't like you to damage your unit by pushing a button *too hard*. Quote Link to comment Share on other sites More sharing options...
