radubogdan Posted December 2, 2020 Share Posted December 2, 2020 Hi, I recently got an HX stomp, awesome piece of metal - I'm happy with the choice. So far it is connected as an interface to my mac (via USB to the computer and outputs TRS - XLR to my Yamaha HS-7) I see no problem practicing bass like this. When I don't practice, I listen to music on monitors and I find it inconvinient to start it everyday just for listening music, so I'm considering adding a scarlett solo in between. 1. Is this a bad setup? 2. Do I loose anything fancy that HX stomp does when it comes to recording? 3. Is there going to be any latency or risks? Explain: Focusrite Scarlett -> Yamaha HS7 as interface to Mac (listening music layer) HX Stomp L/Mono outout TRS -> XLR into mic scarlett solo (playing bass layer + recording) This way I hope to to not turn on the HX stomp everytime, besides the volume knob on scarlett is much cooler :) Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 2, 2020 Share Posted December 2, 2020 IMHO you would be better off adding a mixer. If you already have the Scarlett then you would just route both the HX and Scarlett to your mixer. If you do not already have the Scarlett then you could run the Mac line out to the mixer. You would not losing any recording capabilities of the HX, but you would be introducing an extra AD/DA conversion which would increase the latency. If the latency is perceptible it would be challenging to record properly. Quote Link to comment Share on other sites More sharing options...
radubogdan Posted December 2, 2020 Author Share Posted December 2, 2020 Thanks for the reply @Triryche. I should've mentioned, I have the Focusrite Scarlett Solo already (and I don't own a mixer). I'm asking this because I don't have an extra cable so I can't test the setup myself and I was hoping someone else ran into issues and save me from spending 20€ on cable :) I might find an instrument cable, would it work from L/Mono on HX Stomp to intrument input on Scarlett Solo? Am I risking anything? Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 2, 2020 Share Posted December 2, 2020 You can use an instrument cable but you would plug it into the Line In on the Scarlett. Honestly until you get a mixer you better off just using the Stomp is likely the best approach. Also there should be no "warm up" needed. Quote Link to comment Share on other sites More sharing options...
radubogdan Posted December 2, 2020 Author Share Posted December 2, 2020 Quote Honestly until you get a mixer you better off just using the Stomp is likely the best approach That's what I'm going to do. Thanks a lot :) Quote Also there should be no "warm up" needed. I'll edit my first post to avoid confusion. What I meant was, it feels strange to power the stomp only for the purpose of listening music (especially since I noticed it gets a bit hot) Quote Link to comment Share on other sites More sharing options...
