Jimborock88 Posted December 26, 2020 Share Posted December 26, 2020 I tried to connect my helix line 6 to the computer through usb but when I open hx edit it tries to connect but then it says "connection interrupted". how can I do? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted December 27, 2020 Share Posted December 27, 2020 Don't use a Hub Do use a USB 2.0 port Try a different port If you're using a desktop use one of the ports on the rear Try a different USB cable Make sure your computer's Power Plan is set to Performance In Device Manager check that all USB Hubs' Power Management setting does NOT allow the Hub to turn off to save power Uninstall and reinstall HX Edit Make sure that the HX Edit version is v3.0, and that the Helix is on v3.01 Beat your computer severely with a baseball bat 1 Quote Link to comment Share on other sites More sharing options...
