Can you run 2 Line 6 hx effects together?
Deon55
You can run one directly into the next one (outputs of unit 1 > inputs of unit 2)
Or you can put one into an FX Loop of the other unit....
The only downside is that you are going through multiple AD/DA conversions.
FWIW, I used to run an HX Effects in the Loop of my HD500. That setup worked without any issues and I used it until I upgraded to a Helix LT.
1 hour ago, Deon55 said:
@codamedia
Thanks for the response. Can you explain more about the downside of multiple AD/DA conversions?
Every conversion degrades the signal slightly. It would be like taking two audio tapes and constantly rerecording/bouncing something several times. Each dub adds noise. Of course it isn't as obvious in this digital format but it does happen.
