minimolizard Posted January 6, 2021 Share Posted January 6, 2021 Hey y'all, I'm a bass player and a g'tar man in different bands. I bought the Mooer GE250 to cover all the bases but recently have become disenfranchised with it due to the lack of any bass support/amps. One main bug bear is that I can't specify which input pad (+/-dB) to apply to each patch (as the bass is 18v Active and needs a -20dB PAD and the guitar does not) and it's a global setting. From what I can see, this is the same with the POD GO? Surely I can't be on my own in wanting that option in the Input stage ? You guys with passive and active g'tar or basses must have that issue too? I just can't seem to find anything about it online or any one with a similar issue. The end result is that the guitar runs cold and needs extra gain, or I have to remember to adjust the global setting, both of which are not a perfect solution. Thanks for you help. Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 7, 2021 Share Posted January 7, 2021 The input pad on the POD Go is a global settings as well. The input is only about a 6dB reduction, though. If your bass is really that hot, you might need to use the effects return set to line level as an input. The other option you could do is enable the input pad and then change the Volume pedal block to a Gain pedal in your guitar presets. It would act exactly like the Volume pedal, but it allows you add up to 12dB of gain to the max volume (so the maximum toe setting would be +12.0dB instead of 0.0dB as it is with the Volume pedal). 2 Quote Link to comment Share on other sites More sharing options...
minimolizard Posted January 12, 2021 Author Share Posted January 12, 2021 That FX loop hack is perfect. You sir are a genius. Quote Link to comment Share on other sites More sharing options...
minimolizard Posted January 12, 2021 Author Share Posted January 12, 2021 Using that, I just plug my bass into the FX Return and plug g'tar into the main input. Then no worries. Get resolution to a real issue. To answer the question, yes, the bass really is that hot. I'm sat in front of both the Mooer and the POD doing A/B tests..... I think the Mooer is going on eBay soon..... Quote Link to comment Share on other sites More sharing options...
voxman55 Posted January 12, 2021 Share Posted January 12, 2021 4 hours ago, minimolizard said: Using that, I just plug my bass into the FX Return and plug g'tar into the main input. Then no worries. Get resolution to a real issue. To answer the question, yes, the bass really is that hot. I'm sat in front of both the Mooer and the POD doing A/B tests..... I think the Mooer is going on eBay soon..... Out of interest, which Mooer do you have? Reason I'm curious is I very nearly opted for the flagship GE300 which has the 4 mode tone capture, and if you had the GE300 what you found the good/bad points to be as compared to Pod Go? Quote Link to comment Share on other sites More sharing options...
minimolizard Posted January 13, 2021 Author Share Posted January 13, 2021 I have the GE250. To be honest I think it's great. My bug bear was the lack of bass support. I've only had the POD for one day but it's really growing on me. I love the stomp mode, I could just use this in a live situation and be done. I feel there more of a deep dive on the POD to craft your tone. So many settings and easy to use. Plus the community is brilliant, there's so much out there to pick up with presets and Irs. The expression pedal is definitely better with the POD too. The Mooer feels a little more powerful in terms of; no gap in sound when selecting patches and whilst all but 2 of the fx slots are pre filled, you can have everything you need for a tone. (So delay, reverb, amp, cab, OD/Dist, EQ, Gate are in every tone then you can add 2 more) It's possible to get great tones out of either but for functionality and community I'm leaning to the POD. Quote Link to comment Share on other sites More sharing options...
minimolizard Posted January 13, 2021 Author Share Posted January 13, 2021 By the way, if I use the Fx loop, I by pass the tuner.... So after playing with it yesterday I understood what you said about changing the vol pedal to a gain pedal. So I dropped the max gain for the Bass patches by -5dB (and selected Input Pad On) - works a treat and allows me to use the tuner. That is indeed the solution. Nice one buddy - thank you Quote Link to comment Share on other sites More sharing options...
