Sign in to follow this
bigstu666
X3 live
how do i connect my X3 live to audio interface? want to be able to use plug-ins, but still be able to use my X3 live?
Your X3 Live is an audio interface. No need for a separate one unless you have a specific reason for it.
The simplest setup would be to connect your X3 Live to your computer via USB and configure your DAW to use it and it’s ASIO driver as the audio input and output device. You can then select from the X3’s USB Send channels (see manual) as the Record Input source when you arm a track for recording in your DAW. You can arrange an X3 preset to have an effected Tone 1 and a dry guitar signal (no amp/FX) in Tone 2. You can then record the stereo Tone 1 and the dry Tone 2 simultaneously. Following that you will be able to apply whatever plugins you like to the dry tone.
