coolguy26507 Posted January 17, 2021 Share Posted January 17, 2021 Hello, I've been trying to connect my Spider IV to my computer and nothing seems to be working.. It keeps saying :No Line 6 Device Found" Is there anyway to solve this? Thanks, Evan Edit: Its a Spider IV 15 Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted January 18, 2021 Share Posted January 18, 2021 How are you trying to connect it? The only way to do so is with a FBV MkII pedal (Express or Shortboard). Quote Link to comment Share on other sites More sharing options...
coolguy26507 Posted January 18, 2021 Author Share Posted January 18, 2021 2 hours ago, fflbrgst said: How are you trying to connect it? The only way to do so is with a FBV MkII pedal (Express or Shortboard). I was using that. Is it a specific cable? I was using a cable that could fit Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted January 19, 2021 Share Posted January 19, 2021 23 hours ago, coolguy26507 said: I was using that. Is it a specific cable? I was using a cable that could fit It's a standard USB equipment cable, square end on the pedal side, standard USB on the other end. Should have come with the pedal, if you bought it new. A CAT5 cable connects the pedal to the amp. Don't connect the FBV MkII to the computer with a CAT5 cable. Quote Link to comment Share on other sites More sharing options...
coolguy26507 Posted January 19, 2021 Author Share Posted January 19, 2021 51 minutes ago, fflbrgst said: It's a standard USB equipment cable, square end on the pedal side, standard USB on the other end. Should have come with the pedal, if you bought it new. A CAT5 cable connects the pedal to the amp. Don't connect the FBV MkII to the computer with a CAT5 cable. Ok. So just an Rj45 to USB adapter to my pc and it should work? Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted January 20, 2021 Share Posted January 20, 2021 On 1/19/2021 at 11:43 AM, coolguy26507 said: Ok. So just an Rj45 to USB adapter to my pc and it should work? No no no! There are 2 jacks on the FBV Mk11 pedal - one is the RJ45 (Cat5) for connecting the pedal to the amp. The other is a USB (square type) for connection to a computer. If you connect the RJ45 to your computer you could fry the pedal. Quote Link to comment Share on other sites More sharing options...
coolguy26507 Posted January 21, 2021 Author Share Posted January 21, 2021 22 hours ago, fflbrgst said: No no no! There are 2 jacks on the FBV Mk11 pedal - one is the RJ45 (Cat5) for connecting the pedal to the amp. The other is a USB (square type) for connection to a computer. If you connect the RJ45 to your computer you could fry the pedal. Alright got it. Thanks Quote Link to comment Share on other sites More sharing options...
Aubrey425 Posted April 20, 2021 Share Posted April 20, 2021 Unplug the power cable for the router from the power source. Unplug the power cable for the modem from the power source. Wait at least 30 seconds or so. Plug the modem back into the power source. Plug your router back into the power source. On your PC, try to connect again. oursainsburys Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted April 28, 2021 Share Posted April 28, 2021 On 4/20/2021 at 2:52 AM, Aubrey425 said: Unplug the power cable for the router from the power source. Unplug the power cable for the modem from the power source. Wait at least 30 seconds or so. Plug the modem back into the power source. Plug your router back into the power source. On your PC, try to connect again. oursainsburys Spammer? No wireless connection in what is being discussed here. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted August 23, 2021 Share Posted August 23, 2021 Yes it is. Thank you. I'll hide yours too since the link there also functions. Quote Link to comment Share on other sites More sharing options...
