Pod Go Straight into Studio Monitors causes crackling after I have been playing for a few minutes
theoellingsen
Hey Everyone, I have got my Pod Go hooked up to a pair of PreSonus Eris 4.5 studio monitors, and I have been using this setup for about a month. Recently it started to really bug me that when I play on some presets that I have made, after I have played for ~3-4 minutes, the speakers will start to crackle when I hold a note. I have recorded the sound and put it on soundcloud, if you would like to listen here is the link (You can faintly hear the crackle at the end of the recording, it sounds worse in person): https://soundcloud.app.goo.gl/eGpZ7
I have been trying hard to find a way to fix it, have changed all of my leads, moved to different power supplies etc. to test if it was a grounding issue. No matter what I try, the crackle always comes back. Is it because the signal out of the Pod Go is too hot for the speakers in some of my higher gain presets? Or am I overheating my speakers? Would putting a cheap audio interface between the Pod Go and the monitors would help? I'm really hoping someone has an answer for me, thanks in advance.
Just to be sure, did you record with a mic the sound of the studio monitors?  If not, if just recorded through DAW and Go, then has little to do with the studio monitors...
Also I couldn't hear any crackling.  Are you talking about a sort of 'wobble' in the sound?  To me it sounds almost like a tremolo or like you have some sort of phase issue.  I can also hear some background noise, like some hiss in the background, is that what you're referring to?
Also, either the issue is with the Go, with the speakers, or just with a special combination of both... If it's from the Go, you'd likely get the same issue with headphones or through USB.  Are you?  If it's the speakers, well, should do the same with just music.  Does it also occur on both speakers or just one of them?  All patches, or just that one patch?  If when you're getting the issue, you edit your patch to remove some of the effects, does it have any effect on the crackle?  If you switch patch, does the issue go away and come back 5m later?  If you turn the Go on and off the issues goes away and come back 5m later?
