claudeu
How to get wah block full range 1-100%
I want the expression pedal to control by Exp2 the position parameter of a wah block going from 0-100% using the full range of the pedal.
Instead of this the range is limited e.g. 0-35%. I am using a Boss EV-30 which I connected by a stereo cable. Exp1 should switch the wah off on 0%.
I played with the minimum knob of the pedal and all the settings of the HXstomp. Nothing helped. Perhaps someone could give me his wah settings?
I found out after many tries:
The mistake was I was turning the minimum knob of the Boss EV-30 pedal. It should stay in the "0" Position.
Turning back to "0" will not be accepted by HX stomp. The Wah range is still limited.
The solution was, you have to unplug the cable, check that the minimum knob is in the "0"-position and plug in the cable again.
Now everything is fine.
