huzzam Posted February 25, 2021 Share Posted February 25, 2021 Hi everyone, I'm a longtime HX Effects user, and would like to use the HXFX to control Native in the same way as I do for the hardware effects. I'm finding this very cumbersome & slow. For example, in Ableton I've had to first individually map each CC Toggle / Expression value to a "switch" in the plugin's "configure" interface, and if I want one switch to control multiple things (easy on HXFX), I have to assign it to multiple "switches" in "configure". THEN I have to map these switches to the switches inside the Helix Native plugin itself. This wouldn't be so bad if I just had to do it once, but there is seemingly no way to SAVE these mappings anywhere. So I have to continually RE-DO all this, which means it takes ~20 minutes just to insert the plugin. Is there any way to integrate HXN with HXFX better, so that the switches/expression pedals in the plugin itself are mapped (and these mappings are saved)? There's that enticing "MIDI In" indicator bottom right in the plugin, which implies there must be a way for the plugin to directly receive MIDI, but I've never figured this out. Any help would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
