ulfrune Posted March 3, 2021 Share Posted March 3, 2021 Help! I want to use my HX stomp with ableton live. Im setting everything up but I cant find how i can nonnect a synth to input 5 and 6 and simultaniously use my guitar on 1. Everything I get into ableton is guitar on all chanels. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 3, 2021 Share Posted March 3, 2021 Plug the synth in to the Return(s). Put the Return Blocks on Path B. Pull down the Mixer Block to separate the Outputs. Use USB 3/4 to bring it into Ableton. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 4, 2021 Share Posted March 4, 2021 Couple things I didn't mention. At the split block, Pan the signal LEFT/A100. That prevents guitar from mixing with the synth. At the Path B Output Block, if you're using RETURN L/MONO, Pan the Output Full Left. That puts 100% of the signal onto USB 3. Vice versa if you're using RETURN R. Quote Link to comment Share on other sites More sharing options...
