blh18 Posted February 24, 2014 Share Posted February 24, 2014 Hi all, I've seen a video for the HD 500 where pressing the control key allows copying of patches. I've tried that on my Mac with the 500X but nothing happens. Does antone know the answer please? Failing that there's always the dreaded manual. Thanks Quote Link to comment Share on other sites More sharing options...
brian6string Posted February 24, 2014 Share Posted February 24, 2014 Try the Option (aka Alt) key instead of the control key on the Mac. Quote Link to comment Share on other sites More sharing options...
joebutterfield Posted February 25, 2014 Share Posted February 25, 2014 Blh18, Select the preset you would like to move, option click while moving and you will see a green + icon. From there you can move wherever you would like. @line6jbutter Quote Link to comment Share on other sites More sharing options...
blh18 Posted February 26, 2014 Author Share Posted February 26, 2014 Thank you both for responding I appreciate the help. I do have one other question if you can be bothered answering. How do I delete unwanted patches? Thank you again. Quote Link to comment Share on other sites More sharing options...
jandrio Posted February 26, 2014 Share Posted February 26, 2014 Just save a "blank" patch over the unwanted ones. Quoting from http://line6.com/support/topic/3489-pod-hd500x-patch-questions/?do=findComment&comment=22866 There is no 'delete' function. You delete a patch by overwriting/replacing it with a different patch. The easiest way to do this is to use the editor and drag/drop an 'empty' patch to the location you want to delete. You can create an empty patch, or use the New Tone preset that comes with the User setlists in the factory presets. Quote Link to comment Share on other sites More sharing options...
blh18 Posted February 26, 2014 Author Share Posted February 26, 2014 Thanks for that. How simple.......I am. 1 Quote Link to comment Share on other sites More sharing options...
blh18 Posted March 5, 2014 Author Share Posted March 5, 2014 Can anyone tell me if it's possible to rename the set list categories such as 'User 1' on the 500X and if it's possible, how to do it? Thanks for any help you can give. Quote Link to comment Share on other sites More sharing options...
duncann Posted March 5, 2014 Share Posted March 5, 2014 Absolutely. Go to the 'setlist' tab in HD500X edit and slow double click -- left or right -- the setlist you want to rename. I don't know how to do this without hdedit though. Quote Link to comment Share on other sites More sharing options...
blh18 Posted March 6, 2014 Author Share Posted March 6, 2014 Thank you both for your help. It is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
indabaman Posted June 25, 2014 Share Posted June 25, 2014 I have a HD Pro Rack Mount. How do I go about copying (not moving) one patch to another location? This seems like an obvious system rquirement for a pro player, but I cannot find this function anywhere. I'm therefore overlooking something very simple. Please help. Indabaman. Quote Link to comment Share on other sites More sharing options...
duncann Posted June 25, 2014 Share Posted June 25, 2014 I have a HD Pro Rack Mount. How do I go about copying (not moving) one patch to another location? This seems like an obvious system rquirement for a pro player, but I cannot find this function anywhere. I'm therefore overlooking something very simple. Please help. Indabaman. Hit the save button on the patch you want to copy. Then use the knobs underneath the screen (1 for setlist and 2 for destination) to select the location for the copy. Then just hit the save button again. Quote Link to comment Share on other sites More sharing options...
jandrio Posted June 25, 2014 Share Posted June 25, 2014 or use the HD Edit s/w and proceed as follows (copied from POD HD500 Edit Pilot's Guide v2.0 - English ( Rev A )): Copy & Paste a Preset to a new Channel location: Click on a Preset to select it. Then holdyour Option key (on Mac®) or Ctrl key (on Windows®) and click and drag the Preset to thenew desired Channel location. This replaces the Preset in the destination location. (Note that itis not necessary to hold any modifier key when dragging a Preset between two different Set ListPanels to copy into the new location.) Quote Link to comment Share on other sites More sharing options...
oseito74 Posted August 22, 2017 Share Posted August 22, 2017 thanks a lot, mate. 1 Quote Link to comment Share on other sites More sharing options...
