Connecting to a vox
Buggaluggz
There is no ‘best’ way in terms of sound. Whatever sounds best to you is best for you. The most flexible way, however, would be to use the 4 Cable Method (4CM) as described in the HX FX Cheat Sheet that came with your device (assuming your amp has an FX Loop). That allows you to place your individual HX FX  blocks before or after your amp’s preamp section in the signal chain. If you’re not familiar with 4CM do a little research to understand the benefits.
The set of things I know I don’t know is far greater than the set of things I think I do know. :-)
Does my Roland Jazz Chorus 55 amp have an FX Loop? No googling the answer....
“There are the known knowns, the known unknowns, ....”
14 hours ago, rvroberts said:
I'm surprised you don't know AC30s don't have FX loops,.....
Except for the handwired ones, all the modern production AC30s have FX loops. I have an AC30C2 and wouldn't have bought it without an FX loop. I run it in 4CM sometimes and it's great.
  • Thanks 1
