msly Posted March 17, 2021 Share Posted March 17, 2021 Very odd. It has been working for over a month or so without issue. All of a suden I try to launch the program and it looks like it might load then nothing. I tried uninstalling and re-installing the program. Is there any guidance on this? Should I un install anything line 6 on the computer? Thanks! Mike Quote Link to comment Share on other sites More sharing options...
voxman55 Posted March 17, 2021 Share Posted March 17, 2021 Have you gone into task manager to see if there are multiple tasks for it? if so, close them all down & then try & reopen Pod Go Edit. If they won't delete, reboot your computer. Even if there are no multiple tasks, reboot your computer. If still a problem, remove Pod Go Edit, reboot, then reinstall it. Quote Link to comment Share on other sites More sharing options...
usedbyanr Posted March 18, 2021 Share Posted March 18, 2021 You didn't say if you were running Windows or a Mac. If it's Windows you should look in the Windows Event View under Application after trying to run the software. You will see the crash information. Did you add anything new like an SD Card? Read my post here. If you did add a new SD Card, pop it out and try running it again. Quote Link to comment Share on other sites More sharing options...
msly Posted March 18, 2021 Author Share Posted March 18, 2021 I will have to check out the SD card issue but I was able to fix backing down to version 1.10 instead of 1.11. Loaded right up and had full access to the Go. Quote Link to comment Share on other sites More sharing options...
