the_gorer Posted March 28, 2021 Share Posted March 28, 2021 Pretty much what the title says: does Spider V 20 work with Spider Remote? I installed the Spider Remote app on my Android phone and then I bought a USB OTG cable and plugged my phone in the amp. Tried to mess around with the settings in the app and... Nothing happened. The amp and the phone do not communicate with each other. Am I missing something here? Quote Link to comment Share on other sites More sharing options...
01GT Posted March 29, 2021 Share Posted March 29, 2021 Remote ver 2.00 and Spider V 20 do work together (at least per Line 6's Remote 2.00 release notes). I have a 240HC head into a Win 10 machine so I can't provide much help to your specific problem. But there are some other threads on Android connectivity with Remote. I recommend you look at those. Quote Link to comment Share on other sites More sharing options...
the_gorer Posted March 29, 2021 Author Share Posted March 29, 2021 ^ Thanks, then my amp must be faulty. Quote Link to comment Share on other sites More sharing options...
01GT Posted March 29, 2021 Share Posted March 29, 2021 9 hours ago, the_gorer said: ^ Thanks, then my amp must be faulty. Just make sure you look at the "Android compatibility and connectivity" threads. Either way, I hope your issue gets fixed. When fixed, please come back here and post the final solution. Good luck! Quote Link to comment Share on other sites More sharing options...
the_gorer Posted March 30, 2021 Author Share Posted March 30, 2021 I already tried connecting three different Android phones to my Spider V 20. None of them was able to recognize the amp and to connect to it. Either my OTG cable sucks, or simply the Line 6 developers need to step their game up and to create a working app. The amount of people complaining about not being able to connect their Android devices to their Spider V amps is just mind-boggling. Do it right, Line 6. Quote Link to comment Share on other sites More sharing options...
sms308 Posted April 2, 2021 Share Posted April 2, 2021 Check to make sure that the amp is turned on first, then turn on the app. Also, if you use an app that determines chords in a song, like Chord AI, you can turn on Chord AI first on your phone/iPad, connect the amp to your device, turn it on and load the app. Then you can hear the song playing through the amp or headphones as you play. If this is out of order it won't work. It works on my Spider V20 mkii. Quote Link to comment Share on other sites More sharing options...
Nolan8314 Posted April 10, 2021 Share Posted April 10, 2021 Did you ever solve this? I am having the same issue. Downloaded the new drivers but the amp isnt even recognized on a PC to use the updater. Are these amps just broken? Quote Link to comment Share on other sites More sharing options...
the_gorer Posted April 21, 2021 Author Share Posted April 21, 2021 On 4/10/2021 at 3:01 AM, Nolan8314 said: Did you ever solve this? I am having the same issue. Downloaded the new drivers but the amp isnt even recognized on a PC to use the updater. Are these amps just broken? No, I haven't solved the problem. I still can't use the Remote app at all. Quote Link to comment Share on other sites More sharing options...
mad_yamaha Posted May 25, 2021 Share Posted May 25, 2021 On 3/28/2021 at 11:03 PM, the_gorer said: Pretty much what the title says: does Spider V 20 work with Spider Remote? I installed the Spider Remote app on my Android phone and then I bought a USB OTG cable and plugged my phone in the amp. Tried to mess around with the settings in the app and... Nothing happened. The amp and the phone do not communicate with each other. Am I missing something here? Hello, I had the same problem, the amplifier did not recognize my mobile phone until I discovered that the OTG adapter has 1P unidirectional signal, connect like this (mobile phone> OTG adapter> USB connector mobile phone> amplifier) this is how it works for me . I hope this is your problem. Regards. Quote Link to comment Share on other sites More sharing options...
the_gorer Posted June 30, 2021 Author Share Posted June 30, 2021 On 5/25/2021 at 11:18 PM, mad_yamaha said: Hello, I had the same problem, the amplifier did not recognize my mobile phone until I discovered that the OTG adapter has 1P unidirectional signal, connect like this (mobile phone> OTG adapter> USB connector mobile phone> amplifier) this is how it works for me . I hope this is your problem. Regards. Hello, my mobile phone uses a USB type C connector, while the OTG adapter uses USB type B standard. Therefore, it is impossible to do what you have described and to connect the OTG adapter directly to my phone. Maybe the trick works on older USB type B phones. Not on mine, though. Quote Link to comment Share on other sites More sharing options...
Darrenfoxcroft Posted January 11, 2023 Share Posted January 11, 2023 On 3/29/2021 at 7:03 AM, the_gorer said: Pretty much what the title says: does Spider V 20 work with Spider Remote? I installed the Spider Remote app on my Android phone and then I bought a USB OTG cable and plugged my phone in the amp. Tried to mess around with the settings in the app and... Nothing happened. The amp and the phone do not communicate with each other. Am I missing something here? Make sure the cable you are using supports data not just charging... Caught me out until I took my Samsung data cable and it suddenly worked Quote Link to comment Share on other sites More sharing options...
Line6Tony Posted March 9, 2023 Share Posted March 9, 2023 We're sorry to see you run into trouble. Please try again with the latest version of the Remote app, but only after you update your Spider V firmware to version 2.01. Version 2.00 made it so that the Remote app wouldn't work with the Spider V 20 amp. Quote Link to comment Share on other sites More sharing options...
sellismcc Posted June 26, 2023 Share Posted June 26, 2023 On 3/9/2023 at 12:53 AM, Line6Tony said: We're sorry to see you run into trouble. Please try again with the latest version of the Remote app, but only after you update your Spider V firmware to version 2.01. Version 2.00 made it so that the Remote app wouldn't work with the Spider V 20 amp. How can you update the firmware if the App won't connect to the amp? Quote Link to comment Share on other sites More sharing options...
HProctor Posted July 22, 2023 Share Posted July 22, 2023 My v20 amp is not recognized by any of the software, Remote or the firmware updater. Connected to a Windows 10 PC, nothing I do seems to change this. What should I do ? \ Quote Link to comment Share on other sites More sharing options...
juanemilio Posted August 17, 2023 Share Posted August 17, 2023 Me pasó lo mismo, cambie el OTG y ahora correcto Quote Link to comment Share on other sites More sharing options...
