mk1900 Posted March 30, 2021 Share Posted March 30, 2021 Hi, If I need to connect in the two scenarios as below: 1. One vocal mic (1/4" jack) and an electric violin (MIDI jack): I need to connect the mic to the Input > L/Mono and violin into the MIDI > IN? 2. One vocal mic (1/4" jack) and an electric violin (1/4" jack): I need to connect the mic and violin to Input > L/Mono & Input > R ? Please advise. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted March 30, 2021 Share Posted March 30, 2021 Seems that what you propose should work. Give it a try. You may need to adjust the level inputs to accommodate your Mic and Violin signal levels. Are you also planning to connect a Guitar. BTW, I do not have the XL. I have the HX Stomp. Post back your findings to share what works for you with others whom may be following this thread. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 2, 2021 Share Posted April 2, 2021 On 3/30/2021 at 11:53 AM, mk1900 said: Hi, If I need to connect in the two scenarios as below: 1. One vocal mic (1/4" jack) and an electric violin (MIDI jack): I need to connect the mic to the Input > L/Mono and violin into the MIDI > IN? 2. One vocal mic (1/4" jack) and an electric violin (1/4" jack): I need to connect the mic and violin to Input > L/Mono & Input > R ? Please advise. Thanks in advance. As MusicLaw mentioned, give it a try, might work great. In the case of the HX Stomp XL, which does not have an XLR input, depending on which mic you are using, adding a mic preamp, small mixer, or LowZ/HighZ impedance transformer might improve the mic's sound. "You’ll also find a studio microphone preamp within the Preamp > Mic category."(from the manual). Quote Link to comment Share on other sites More sharing options...
