bdevoe Posted April 13, 2021 Share Posted April 13, 2021 Hey everyone, Im knew to the the helix community.. finally upgrading from the 11rack. I am having difficulty getting my helix set up in logic pro x, what I am trying to do is use the helix as my interface and input source for guitar, but maintain the built in output on my mac, as my monitor speakers go through this. Currently my set up is as follows: guitar in - helix - helix usb - mac I am unable to get even input signal on logic, i have the drivers installed, helix selected as being input and built in output selected as output. I am getting guitar signal on the helix, just not any further. These settings worked perfect with my 11rack, and I've been unable to find a video or anything to help me out lol. Any help is appreciated!! Quote Link to comment Share on other sites More sharing options...
MGW-Alberta Posted April 14, 2021 Share Posted April 14, 2021 I don't use my Helix guitar processor as a computer interface. I plug my Helix guitar processor into a computer interface. Quote Link to comment Share on other sites More sharing options...
soundog Posted April 15, 2021 Share Posted April 15, 2021 Be sure to follow the section on "USB Audio" in the manual. In Logic, on a stereo audio track, enable USB 1/2 as input for recording wet Helix output (Path A) - and/or enable USB 5/6 for dry input (Helix in L/R), or use a mono audio track to just record mono USB 5 guitar input If those USB inputs aren't showing up in Logic, check Audio MIDI Setup and see if your Mac is connecting to Helix OK. Should be... For monitoring/output, there are other steps involved, but let's make sure you are getting input first. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 15, 2021 Share Posted April 15, 2021 On 4/13/2021 at 10:02 PM, bdevoe said: I am unable to get even input signal on logic, i have the drivers installed, helix selected as being input and built in output selected as output. I am getting guitar signal on the helix, just not any further. These settings worked perfect with my 11rack, and I've been unable to find a video or anything to help me out lol. Any help is appreciated!! Hi, Follow the instructions given by “soundog” in the post above, but as you are using a Helix LT, USB 7 will be the default setting for sending the dry unaffected guitar signal to Logic. IIRC, USB 5/6 is default for the HX Stomp. Also, please ensure that your Helix LT is selected as the audio in/out device in the preferences in Logic Pro X. You can use the Apple Audio/MIDI setup utility app to see everything is hooked up correctly. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
soundog Posted April 15, 2021 Share Posted April 15, 2021 Ah, good catch @datacommando. I'm a Stomp user, and assumed all the devices use the same USB in/outs. Guess not! Hopefully all this info should get the OP up and running.... 1 Quote Link to comment Share on other sites More sharing options...
EdwinV Posted April 15, 2021 Share Posted April 15, 2021 As datacommando already stated, goto Logic Pro --> Preferences... --> Audio... and set the Input Device to Helix. Output to whatever you prefer. Not sure if you know, but you can also create "Aggregate Devices" with Audio MIDI Setup (click on the "+" sign in the left bottom corner of the Audio Devices of Audio MIDI Setup. You can search for Mac Aggregate Device on youtube if you can't figure it out. 1 2 Quote Link to comment Share on other sites More sharing options...
soundog Posted April 16, 2021 Share Posted April 16, 2021 A room full of Logic users. Ya can't go wrong! Quote Link to comment Share on other sites More sharing options...
