Firehawk Fx red light A button
Juanes007
  • 1 month later...
  • 2 weeks later...
  On 4/15/2021 at 3:16 AM, Juanes007 said:
My Firehawk Fx stopped working. Nothing is displayed on the interface. A red light shines at the "A" button. Nothing so far has worked: Factory reset, connecting it through the USB and trying to update it.
Expand
Could be the SDcard inside, sometimes you just need to remove and insert again
You need to remove, the screws at the back side (NOT THOSE IN THE MIDDLE) only the screws at the plastic support
Now you can slide de front and remove carefully
Now remove all the nuts and the screws at the ouput side
 You will see  a large and a little electronic board, turn CAREFULLY the little one and you will see the  micro sd card 8 GO class 4
Try to remove it and insert again you can power on the FH to take a look if restart or not
If not :
The image is broken on the Sdcard you need to reinstall a new .bin image on  the sd card
 The sd card can be fixed with a little bit glue, take care to not add glue on the connector of the sd card
Expand
Solid A button would indicate the SD is detected, but firmware was not found on it. It's unlikely the card is loose/dislodged. That scenario typically has only the display backlight on(dim blue light, no text) with no switches lit up.
Expand
Try it first
otherway = rewrite the firmware on the sdcard with  imageUSB (free software don't need to instal, just launch)
  On 5/31/2021 at 6:01 PM, Punkyboy said:
 Some people say that sometimes just need to move the sd card works !
Expand
I know you are just trying to help. But I don't think you fully understand how the unit works. Or how to recognize the various ways it can fail to start up. I've done extensive research and testing on the Firehawk FX. It's not guesswork. When the A Button is lit solid the problem is NOT the SD card being loose or missing. The Firehawk has detected the card if the A button is lit, but was unable to load the firmware. Meaning it's a problem with the firmware itself. It's either not on the SD card or the data was somehow corrupted.
It's not difficult to take the Firehawk apart, but there's a fair amount of time and energy required to do it. There's no point in recommending someone disassemble their unit when it stands no chance of fixing the problem.
  • 1 year later...
  • 1 year later...
