Interesting...Poly and Retro Reel combination
DunedinDragon
I discovered something interesting as I was meddling with one of my older presets using 3.1.  I had to raise the key for the singer so I ended up using the Poly Capo to go from the key of G to A.  I've had a fair amount of success with the Poly Capo placing it before the amp, but it still exhibits some very slight artifacts.  Nothing that would probably be noticed by the audience, but I can hear it on certain things.  I decided to place the Retro Reel in front of the Poly Capo originally just to thicken things up since I was using a Strat.  After a bit of tweaking it pretty much got rid of any of the residual artifacts I'd been hearing and gave the key change a much more natural sound.  Just thought I'd pass that along....
  • Thanks 1
  • Upvote 2
Yeah, I totally believe that.
I do get a similar result using just a bit of compressor and rolling back the guitar tone to reduce harmonics, which is the same thing I do when I need some pitch to midi conversion. It works.
