FBV MKII Express/PodHD ProX Not Working?
Hi, I picked up a Express MKII not too long ago and I havent been able to get it to work with my pod.  I plug it in and the lights on the tuner flash and then thats it. I can calibrate it but still doesnt work after that.  None of the buttons work/light up nor does the volume pedal. Tried a different cable and updating all the software, even factory reset my pod and still nothing.  Is there something I am missing? I really only want to use the pedal for tuning and the pitch shifter effect
This is with a CAT5 cable, correct?  Check the pedal's pin contacts in the jack to make sure none are bent.
Is this a brand new or used FBV?  The symptoms you describe sound like an FBV that had a glitch when updating the firmware.
Tried it with the CAT5 cable I got with it and another one I had. Nothing looks bent in the pedal or the pod...
I got it used but I made sure the guy showed me it worked on his spider amp with no problem. I had this issue before I attempted to update my pod and my pedal. Is there anyway to fix this?
  • 1 year later...
HOW ABOUT IT, I HAVE THE SAME PROBLEM.. COULD YOU SOLVE IT? THANK YOU
