Melquisedec Posted April 25, 2021 Share Posted April 25, 2021 Hi Guys: I have a trouble. When I connect my pedalboard to effect loop, there is a loss volumen, but when I disconnectt the pedalboard of effect loop the volumen is OK. I use the 4CM (four methode cable) Is it a problem with the tubes? Is it a problem with the effect loop? My pedalaboard is OK, because I use the same pedalboard with other amp y that issue there is not. Help me please. Quote Link to comment Share on other sites More sharing options...
bobcoss Posted April 26, 2021 Share Posted April 26, 2021 Hi, Try plugging an instrument cable from the effects send to the effects return. On mine, the volume is the same both ways. If they are different there could be a problem with the amplifier. I can't imagine that there would be something wrong with the tubes if things work well when there is nothing in the effects loop. When I connect my HX Effects in 4CM, it works great. I get lots of volume. I hope you get it figured out. 1 Quote Link to comment Share on other sites More sharing options...
