arrowhead82x Posted May 12, 2021 Share Posted May 12, 2021 Volume goes from nothing to instantly loud with small movement and then no more change as you go farther forward. Can this be calibrated? I have an EX-1 also and it acts the same. I am connected to a Spider V 240 that has the firmware updated. Quote Link to comment Share on other sites More sharing options...
01GT Posted May 12, 2021 Share Posted May 12, 2021 So you are saying you have this volume-pedal issue whether using the FBV3's on-board pedal or if plugging in an external EX1? For what it is worth, I have the FBV3/EX1 and don't have this problem at all (either using the FBV3 pedal or EX1, the volume pedal works fine for me) so something is definitely wrong. I never performed any calibration on anything. When I went to hook up the EX1 initially, I thought I would have to do something, but the FBV3 instantly re-configured to "wah-only" with the external EX1 acting as a volume pedal, and configures back when unplugged. The current FBV3 firmware version is v1.02 (shows up on the FBV3 display). Besides the latest Spider V 240 firmware, does your FBV3 have this most up-to-date firmware too? If so, maybe even try re-loading the FBV3 firmware anyway. Also, there is a "Line 6 FBV Control" app. I am not sure if this app would help you, but maybe (?). If there is nothing here to help, you likely need to call Line 6 who I am pretty sure can help straighten this out. Quote Link to comment Share on other sites More sharing options...
Stantonn Posted September 11, 2021 Share Posted September 11, 2021 Hi all, I was wondering if anyone knew how to calibrate the treadle on the Line 6 FBV 3 (I checked the Pilot Guide, the Line 6 Forum and the general web, but there is no info available). First Call Online Any assistance would be much appreciated. Cheers! 1 Quote Link to comment Share on other sites More sharing options...
