denisfarr Posted May 14, 2021 Share Posted May 14, 2021 Would this 4 cable method work as a Wet/Dry/Wet scenario with a Helix Floor and a Mesa Boogie JP-2C?: Guitar into Helix Guitar input jack. Helix Loop #1 send jack to Mesa JP-2C guitar input jack. Mesa JP-2C effects send jack to Helix Loop #1 return jack. Helix main output Left and right 1/4" jacks to stereo power amp left and right input jacks. Stereo power amp left and right speaker output jacks to 2 Mesa 1X12 Recto cabs for left and right "Wet" sound. Mesa JP-2C speaker output jack to Mesa 1x12 Recto for center "Dry" sound. Signal path on Helix Patch: Guitar in> Compressor>Overdrive> loop #1 send and return ("Dry" Sound)> Stereo Pitch Shift> Stereo Delay>Stereo Reverb> Helix Main 1/4" left and Right Output (Left and Right "Wet" sound). Also would all cables, other than speaker cables, be 1/4" TS to 1/4" TS? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 14, 2021 Share Posted May 14, 2021 Unless the JP-2C has a parallel FX loop that you can use to route the preamp separately to the JP power amp, you'll need to add an FX Loop 2 Send block between the the FX Loop 1 block and the "wet" FX and and take that send to the JP FX Loop Return to get the JP preamp (the DRY signal) into the JP's power amp>speaker. Otherwise the plan looks solid. 1 Quote Link to comment Share on other sites More sharing options...
denisfarr Posted May 14, 2021 Author Share Posted May 14, 2021 53 minutes ago, rd2rk said: Unless the JP-2C has a parallel FX loop that you can use to route the preamp separately to the JP power amp, you'll need to add an FX Loop 2 Send block between the the FX Loop 1 block and the "wet" FX and and take that send to the JP FX Loop Return to get the JP preamp (the DRY signal) into the JP's power amp>speaker. Otherwise the plan looks solid. Would all 4 cables still be 1/4" TS to 1/4" TS. Would there be any ground loop issues? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 14, 2021 Share Posted May 14, 2021 8 minutes ago, denisfarr said: Would all 4 cables still be 1/4" TS to 1/4" TS. Would there be any ground loop issues? Yes, TS. IF everything is plugged into the same high quality emi/rfi filtered power strip AND there's no problem with the "house" wiring, AND if both amps have a ground switch (Helix FLOOR has one, IDK about the LT/Rack), then you SHOULD be safe. Ground loops are hard to predict or troubleshoot. KISS applies. Quote Link to comment Share on other sites More sharing options...
denisfarr Posted May 14, 2021 Author Share Posted May 14, 2021 Thanks! Quote Link to comment Share on other sites More sharing options...
