bsimmons106 Posted May 22, 2021 Share Posted May 22, 2021 I'm thinking about upgrading from my HF effects to a stomp XL, but I don't want to lose the ability to just bend down and tweak a knob without going into any menus right from stomp mode. Is it possible to do this with the stop XL? Everything I've seen looks like I have to go into edit mode with the menu, select the block and then adjust parameters from there. Is there a way to use capacitative touch and just tweak the knobs like the HX FX? Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 22, 2021 Share Posted May 22, 2021 The capacitive touch switches work the same way on the XL as they do on the HX Effects. Also, don’t forget that there’s Pedal Edit Mode as well (as there is with the HX Effects, too). If you hold down the Mode switch, you’ll go to Pedal Edit mode where you can edit parameters of blocks without having to bend down at all. Quote Link to comment Share on other sites More sharing options...
