Line 6 Spider IV 15 watt Looper/ multieffect pedal board compatibility
Hi guys, I wanted a little help out here.
i have a line 6 Spider IV 15 watt amp. I wanted to get a looper to it and i zeroed down on the boss rc-5 looper. But then I got to know that it wouldn’t work in the amp properly.
so I decided if I should get the line 6 Pod go multi effect pedal.
i want to understand if it’s right decision I’m making since I don’t intend on a buying a new amp at the moment and plan on continuing with the spider IV amp.
it would be helpful if someone could help me get some clarity on this. Thanks
Using a looper on the input of an amp with effects means that you cannot change the amp effects when you add a part to the looped track, as it will change the sound of the loop track as well.  I am guessing that's what you mean by "it wouldn’t work in the amp properly".  The POD GO does not have a looper function.
I find it kind of funny that you are stuck on using a $99 bedroom practice amp,. but willing to spend $500 on an 'all in one' effects pedal!
  • 2 months later...
