Sign in to follow this
arislaf
Pod Hd + Pod Hd500 Best Way To Connect Both?
4CM? And if yes , how to use the looper? On witch pod and where on chain?
Basicaly I want to run  the HD500 to the HD bean...
Thanks!
I would use the "main" POD for the (dual) amps and some FX up to DSP limits and use the "auxiliary" POD for effects, thru the FX loop.
As far as the looper is concerned, it depends for what purpose u intend to use it.
I think that I'd put the HD bean into the FX Loop of the HD500..
the contrary wouldn't be possible
but having eventually a second external amp, I'd much prefer using a guitar signal splitter to do 2 parallel chains, one with the HD500-ext amp1 and the other with the bean-ext amp2
I intend to use for recording, not at all with an amp. So the main idea is use the HD500 for the pre amp effects (pitch shifter ,gate, overdrive) and the bean for dual amps echo, reverb. So what is the best way?
Tank you Jandrio and Hurghanico for helping me out :)
Hurghanico is absolutely right stating that u have 2 run HD-BEAN in2 HD500's effect loop.
c attached pic and demo patches.
Place the looper last in combo-chain (HD-BEAN) if u want it 2 play processed signal, or first in the combo-chain (HD500)  if u want it 2 play unprocessed raw guitar input.
rgds/john
ps
1) Of course there r several other ways 2 implement the HD500+BEAN combo, treat those patches as a starting point only.
2) Cabling: connect HD500 FX send 2 HD-BEAN's guitar input.
    Connect HD-BEAN's usb or 1/4" unbalanced outputs (L+R) to recording device.
HD500_BEAN_combo.zip
Thank you John! ΕυχαÏιστω!!!! Very useful info !
Create an account
Register a new account
Sign in
Sign In Now
