cwelling Posted June 4, 2021 Share Posted June 4, 2021 Helix Floor connected to 2 Powercab112+ linked with AES for a stereo rig. When I edit, I can only see one in the Powercab Edit software. I'd like both cabs to have the same setup, but didn't know if it was possible for my changes to be automatically passed through to the 2nd Powercab when I edit, without having to save a backup, hook up the 2nd cab and then restore which, though not terrible, seems a bit klunky. Even better if this would work in Helix Edit as well. Any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
CMO79 Posted June 15, 2021 Share Posted June 15, 2021 Hey cwelling! Haven't seen anyone respond so I'll try if you haven't found your solution already or anyone else comes here and has same question. :) 1.Select your outputs in HX Edit 2. Select the powercab tab section 3.Set remote(control) for preset global or off(controlled on powercab) 4. Select 1+ 2 Link If you don't see these options make sure you have the latest HX Edit and Powercab software is installed with the latest versions. Thanks! Quote Link to comment Share on other sites More sharing options...
cwelling Posted June 22, 2021 Author Share Posted June 22, 2021 Thanks CMO79! I guess I overlooked that in my frustration 1 Quote Link to comment Share on other sites More sharing options...
CMO79 Posted June 24, 2021 Share Posted June 24, 2021 Great enjoy cwelling!! Happy to help showcase that great feature! Quote Link to comment Share on other sites More sharing options...
Wondo100 Posted June 30, 2021 Share Posted June 30, 2021 On 6/14/2021 at 9:12 PM, CMO79 said: Hey cwelling! Haven't seen anyone respond so I'll try if you haven't found your solution already or anyone else comes here and has same question. :) 1.Select your outputs in HX Edit 2. Select the powercab tab section 3.Set remote(control) for preset global or off(controlled on powercab) 4. Select 1+ 2 Link If you don't see these options make sure you have the latest HX Edit and Powercab software is installed with the latest versions. Thanks! And with the above info, If I chose 1 or 2, then I can edit each cab to do its own thing? For example. Cab 1 is FRFR and Cab 2 is speaker? Or Cab 1 and 2 is speaker but each is a different speaker? AND THEN THIS CAN BE STORED FOR RECALL? Quote Link to comment Share on other sites More sharing options...
