Using 2nd path for vocals...
themetallikid
Is using a Gain block essentially the same as the 'Gain' parameter on the vocal preamp model?  It seems for me to get my mic hot enough to sing comfortably....during a few songs (probably how my voice projects) i get some slight distortion .   I'm monitoring my guitar vocals directly into a powered wedge from the 1/4" out, controlled volume wise by the volume knob and then running my XLR to the mixer.
On the Vocal Preamp (Helix is in the car packed yet) I believe I'm on 10 for the output volume and the gain is around 6.5-7.5 I believe.  I hear it and I keep reducing the gain, but its still there on those few songs.  Is it better to have the gain higher and a lower output level?  Or would an extra gain block get me a more cleaner sound.
Its not horrible distortion or even really a nasty clipping sound...that I know for sure.  Its sorta like if you try and add a slight amount of grit to an acoustic guitar...you get the clean signal, but then a little dirt mixed in.  I'm thinking its coming from the gain parameter in the vocal preamp block....would adding an additional gain block after the preamp or just replacing it entirely be better?
