kjbllc123 Posted June 25, 2021 Share Posted June 25, 2021 new to all this , I have cubase daw, I get the iimpression you can make your own ir"s looked at some utube stuff, but still seems kind of foggy on the basic idea or irs and how to make them. thank, I have the helix lt . kevn Quote Link to comment Share on other sites More sharing options...
kjbllc123 Posted June 25, 2021 Author Share Posted June 25, 2021 I am looking to make them for mandolin and violin. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 25, 2021 Share Posted June 25, 2021 Do you have a mandolin and a violin each with electric pickup? Then you would record both the pickup signal and a mic'ed signal at the same time. Then you would use a match eq plugin to match the pickup with the mic signal as source. If that then sounds good, you can use a deconvolver plugin to bake the eq into an ir. 1 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted June 26, 2021 Share Posted June 26, 2021 17 hours ago, kjbllc123 said: I am looking to make them for mandolin and violin. An interesting link on the topic. You can purchase IRs for mandolin and violin as well. https://www.3d-varius.com/impulse-response-acoustic-instrument/ Quote Link to comment Share on other sites More sharing options...
kjbllc123 Posted June 27, 2021 Author Share Posted June 27, 2021 yes thanks, I found a couple but some do not work on helix. Quote Link to comment Share on other sites More sharing options...
Fenderflame28 Posted June 27, 2021 Share Posted June 27, 2021 I shared the process I used when I made my own IRS for my DT25 amp here: DT25 IRs Hope this helps. Quote Link to comment Share on other sites More sharing options...
