noiseplow Posted July 1, 2021 Share Posted July 1, 2021 I'm using the HX Effects with a Voodoo Lab Control Switcher to change the channels on a Dual Rectifier and it works great. I have it set up as follows; Footswitch 4: Amp Channel 1 (Modern) Footswitch 5: Amp Channel 2 (Raw) Footswitch 6: Amp Channel 3 (Clean) The Footswitches act as you'd expect in this situation. If it's set to 'CC Toogle' with the mode set to 'Latch' instead of 'Moment'(Momentary), when Footswitch 4 is selected, the LED ring turns on and the Amp is set to Channel 1. Now if I click Footswitch 6 for the Amp's Clean Channel, the Amp changes to Channel 3 correctly but now both Footswitch 4 and Footswitch 6 LED rings are on/lit. If I use 'Midi CC' instead of 'CC Toggle' then the LED ring doesn't turn on at all (Midi CC doesn't have the option to select 'Latch' or 'Moment'(Momentary)). What I want is when Footswitch 6 is activated, both Footswitch 4 and 5's LED rings are turned off so I can see which Amp Channel is active by looking at the HX Effects (instead of having to turn around and look at the amp). My question is: is there a way to turn off other footswitch LED rings when a footswitch is selected? Or should I be using Snapshots for this? The current setup works great because I have 3 Amp Channels across the bottom 3 HX Effects Footswitches all color coordinated to the AMP's Channels (Red, Orange & Green) Cheers, A Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 1, 2021 Share Posted July 1, 2021 If it was 2 channels this could work, but not with 3. I would use Snapshots for this. You don't get color coding, but you still have your Stomps available for other uses. IIRC, color coded Snapshots are planned for a future update. Quote Link to comment Share on other sites More sharing options...
noiseplow Posted July 2, 2021 Author Share Posted July 2, 2021 Thanks for the response. It's what I figured. I may just go back to using the Rectifier pedal for Amp Channel changes and keep the HX Effects for effects. Thanks again, Cheers! Quote Link to comment Share on other sites More sharing options...
