pochiiboi Posted July 14, 2021 Share Posted July 14, 2021 I recently tried Helix Native, a week after, I was curious on why my DAW freezed. I tried to do programming with cmd and powershell if the solution would be there but no luck. So I tried it in another DAW and it also freezed, so I went back to the DAW that I usually use and tried a different plug-in and there seems to be no problem at all, when I inserted the Helix Native, it freezed again. Is there any solution to this issue? I've read a few forums and I didn't see any solution for this. Hopefully Line6 would fix it cause it has great tones and I just recently finished getting my tone and it would be a waste if it just freeze everytime. Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 15, 2021 Share Posted July 15, 2021 21 hours ago, pochiiboi said: I recently tried Helix Native, a week after, I was curious on why my DAW freezed. I tried to do programming with cmd and powershell if the solution would be there but no luck. So I tried it in another DAW and it also freezed, so I went back to the DAW that I usually use and tried a different plug-in and there seems to be no problem at all, when I inserted the Helix Native, it freezed again. Is there any solution to this issue? I've read a few forums and I didn't see any solution for this. Hopefully Line6 would fix it cause it has great tones and I just recently finished getting my tone and it would be a waste if it just freeze everytime. I can assure you that it doesn’t freeze every time for everyone. I just finished mixing a huge project where I had like a dozen or so instances of Native, and it worked fine the entire time. It would be helpful if you gave some more information. Telling us what type of machine and what operating system are you using, and what DAWs have you tried would be a start. Quote Link to comment Share on other sites More sharing options...
pochiiboi Posted July 15, 2021 Author Share Posted July 15, 2021 Hi Phil, I've also seen many forums about my problem which is when they Helix Native, It would freeze but the sound is still there, I haven't found a solution from the other forums. I have a low spec laptop and at the time when it was not frozed, I had no issues with it so far until now. Some people have a mid-high range laptop and they still encounter these issues. I checked my CPU usage and it only reaches 10% usage for my DAW itself on the cpu. I used reaper and Cakeealk but my main is cakewalk Hoping that someone would give me a solution! Quote Link to comment Share on other sites More sharing options...
