Snuggs Posted August 20, 2021 Share Posted August 20, 2021 I was just given a Variax Standard. It didn't have the battery, charger, or cable. I'm a little confused about the cable though. If I only need to cable to connect to Workbench, is it the RJ45/USB cable that I need? Do I need to connect to Workbench if I'm satisfied with the preloaded models? I keep seeing a VDI cable mentioned. I think that's if you have a certain Line 6 floor pod, you can power the Variax Standard with this cable and no need for a battery. Am I understanding this correctly? Also, is the JTV battery the same as the Standard? TIA Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted August 20, 2021 Share Posted August 20, 2021 If I only need to cable to connect to Workbench, is it the RJ45/USB cable that I need - You need the USb interface Do I need to connect to Workbench if I'm satisfied with the preloaded models? - No I keep seeing a VDI cable mentioned. I think that's if you have a certain Line 6 floor pod, you can power the Variax Standard with this cable and no need for a battery - exactly is the JTV battery the same as the Standard - Yes You can not update the firmware of your variax without he usb interface WIth the Vdi cable and a Pod Hd 500x Or Helix you can launch workbench without the usb interface ! Quote Link to comment Share on other sites More sharing options...
Snuggs Posted August 20, 2021 Author Share Posted August 20, 2021 Thanks so much, Punky! Quote Link to comment Share on other sites More sharing options...
