Helix LT blank screen and red line during loading
GregV
Hi Everyone!  I haven't been here for a long time!  I hope everyone's doing well.
I just tried to load the latest firmware to my Helix LT.  Using a MacBook Air with Big Sur.  Successfully created a backup (I think) but the firmware update process failed.  It said "restart and try again".  But now the Helix won't boot up at all.  I see the Helix logo for about a second and then a red line crawls across the screen.  The screen stays black with the red line across it.
I found a thread on here that showed a dozen different "factory reset tricks" by holding down foot switches while powering up, but none of them have had any effect.  Black screen/red line.
HX Edit says "no device connected".
At this point the firmware update is inconsequential.  I just want a living Helix again.  Any thoughts?
Greatly appreciate any and all support!
Thanks everyone,
Greg
Sorry for the false alarm... I figured out a solution!
I used the Line 6 Updater, but I had to force it to install because Big Sur said "it couldn't scan for malicious content".  After forcing the software in, I reboot the Helix with foot switches 6 & 12.  (Force Reboot, I think.  It's the one that gives nothing but a blank screen)
Then Updater could do its thing!
Back up and running.  (HX Edit is now working better too)
I hope this helps someone else at some point...
Have a great day!
  • 11 months later...
Hello, I've the same problem:
I started updating my helix lt with the line 6 Updater. But then it canceled. After this moment my helix shut down with a black screen and a red line - neither the helix lt is connected to the computer nor not.
Can you explain what you did to solve the problem a little more accurate? That would be great!
I use a windows 10 computer.
Looking forward to your awnser.
Best regards
