How to send program change up/down messages from Helix?
dmoracze
I know it's possible to send an absolute program change from the command center, but is it possible to send a 'program change up' message? That is, if I'm on pc 1, the switch will change it to 2, next time to 3, and so on...
I want functionality like the Midi Mouse, but on the Helix. That is, I want to keep the same Helix preset but send incremental program changes using the command center.
I think, the answer is "no", there's simply no option for that inside the Command Center. Your best bet would likely be to have a look whether the receiving unit would possibly support translating other messages into "program up/down".
If the receiving unit recognizes an Up/Down MIDI message, yes. If not, then no.
For instance, using Helix as a controller for Amplitube, you can use the Amplitube LEARN function to use any momentary CC assigned to Helix Footswitches to do Preset Up/Down.
Other devices/sims might have hard-wired CCs for this.
